FaiKee Opublikowano 31 Sierpnia 2013 Zgłoś Opublikowano 31 Sierpnia 2013 There is a lot of posts in various sites telling people how to install and activate windows 8.1 Pro+WMC, it needs the user to go thru a lot of procedures and phone activate, the first time he installs and everytime he re-installs, there is a cleaner and more simple method: make a install.wim that when installing, it activates by itself upon installation completion. Needs you to have a activated win8WMC(with your own key), work on the win8.1 wim, the tokens.dat and data.dat are from the win8wmc:dism /mount-image /imagefile:f:\install.wim /index:1 /mountdir:e:\mountDism /Image:e:\mount /enable-feature /featurename:NetFx3 /All /Source:k:\sources\sxs /LimitAccessdism /image:E:\mount /set-edition:ProfessionalWMCcopy e:\tokens.dat e:\mount\Windows\System32\spp\store\2.0 /ycopy e:\data.dat e:\mount\Windows\System32\spp\store\2.0 /ydism /image:E:\mount /set-productkey: (your WMC key)dism /unmount-image /mountdir:e:\mount /committhat's it, compile to ISO with the install.wim, install, and get a activated win8.1WMC. You don't have the corrrect files? don't worry: data.dat + tokens.dat : [Zawartość widoczna tylko dla zalogowanych użytkowników] ~~~~~~~~~~~~~~~~~~~ To-day's Sunday, so I did the steps with win8.1 Pro X86 to show :1. Double click ISO to mount, drive is K:2. Copy install.wim to C; right click -> properties , untick "read only" ; and also take ownership3. Made a folder "mount" in E:4. Have the files tokens.dat and data.dat in E:5. Carry out the DISM commands, with the correct drive code, and the WMC key, you need to do it in 9600 to work on a 9600 wim.6. When done, open the win8Pro X86 with UltraISO, replace install.wim with the modded wim,and add file EI.cfg to sources [Channel]Retail[VL]1 Save to new ISO "win8-1_WMC-X86".7. I used VMWare to install, when asked for edition, choose "Windows 8.1 Pro"; no need to enter key8. Done Win8.1Pro+WMC+Net3.5, X86 win8.1Pro+WMC+Net3.5, X64 Note:- I used this WMC key in a previous machine, since WMC key bundles with machine, after installation it is not activated and requires a phone call.- If you don't wish to fight with DISM, you can download the ISO from MEGA, after installation, enter your own key, if it couldn't be activated on-line, make a phone call. Download : X86 ISO: [Zawartość widoczna tylko dla zalogowanych użytkowników] X64 ISO: [Zawartość widoczna tylko dla zalogowanych użytkowników] Note: use WinRAR_5 to unrar, password : pcbeta-com - On theory, if you installed with my ISO, you could make a phone activation, but then if another guy made a phone call, it might deactivate yours ......... not my problem. Cytuj
razor1995 Opublikowano 31 Sierpnia 2013 Zgłoś Opublikowano 31 Sierpnia 2013 Mam pytanie - w jakim języku jest to forum ? Polskim czy Angielskim ? I have a question - in witch language is this board ? In Polish or in English ? Good tutorial Cytuj
Mr.T Opublikowano 31 Sierpnia 2013 Zgłoś Opublikowano 31 Sierpnia 2013 Polskie forum dla wszystkich trzeba sie dostosowywac Cytuj
razor1995 Opublikowano 31 Sierpnia 2013 Zgłoś Opublikowano 31 Sierpnia 2013 Chyba, że tak - forum international Cytuj
FaiKee Opublikowano 8 Września 2013 Autor Zgłoś Opublikowano 8 Września 2013 win8.1 updates:Download: [Zawartość widoczna tylko dla zalogowanych użytkowników]Windows8.1-KB2883295-x64Windows8.1-KB2884097-x64Windows8.1-KB2884778-x64Windows8.1-KB2885706-x64Windows8.1-KB2884097-x86Windows8.1-KB2884778-x86Windows8.1-KB2885706-x86 Cytuj
FaiKee Opublikowano 8 Września 2013 Autor Zgłoś Opublikowano 8 Września 2013 win8.1 VLSC is out Cytuj
ismet412 Opublikowano 8 Września 2013 Zgłoś Opublikowano 8 Września 2013 Thank' a lot good eplanations i'll try this all Cytuj
FaiKee Opublikowano 24 Września 2013 Autor Zgłoś Opublikowano 24 Września 2013 I don't know if these are still valid or not, try your luck with phone Office 2013 MAK : FPPWN-DDX66-W9YK7-RFW4J-MTBG7 Win8.1 Enterprise: Another 8.1 Ent still valid(for phone): YNH48-C938B-RTVMD-GGKTY-RCYDQ Cytuj
Gość unloved Opublikowano 11 Października 2013 Zgłoś Opublikowano 11 Października 2013 how i can make same metod turkish rtm? english ur perfect can i create turkish Rtm? pls help me sorry for my english Cytuj
Gość unloved Opublikowano 11 Października 2013 Zgłoś Opublikowano 11 Października 2013 ok ok i solved i added language pack tr-tr in this x64 DVD thank youuuuuuuuuuuu Cytuj
Gość maxmm99 Opublikowano 16 Października 2013 Zgłoś Opublikowano 16 Października 2013 method 1 please I cant understand Cytuj
FaiKee Opublikowano 17 Października 2013 Autor Zgłoś Opublikowano 17 Października 2013 method 1 please I cant understand If you can't do it by yourself, then just download the ISO. Cytuj
Gość unloved Opublikowano 23 Października 2013 Zgłoś Opublikowano 23 Października 2013 [Zawartość widoczna tylko dla zalogowanych użytkowników] Cytuj
dgnghia Opublikowano 29 Kwietnia 2014 Zgłoś Opublikowano 29 Kwietnia 2014 active win 8.1 by phone Now i want update windows media center free help me. thks very much Cytuj
dgnghia Opublikowano 29 Kwietnia 2014 Zgłoś Opublikowano 29 Kwietnia 2014 c:\\Control Panel\System and Security\System và Click vào Get More Features with a new edition of Windows 2. Click vào I already have a product key. 3. Nhập vào Key Win 8 Pro WMC4. Tick vào ô accept the license terms và click Add Features I using win 8.1 pro active by skp phone , But I don't "Add Features" for PC info thksss Very mush Cytuj
Qubi Opublikowano 5 Lutego 2015 Zgłoś Opublikowano 5 Lutego 2015 There is a lot of posts in various sites telling people how to install and activate windows 8.1 Pro+WMC, it needs the user to go thru a lot of procedures and phone activate, the first time he installs and everytime he re-installs, there is a cleaner and more simple method: make a install.wim that when installing, it activates by itself upon installation completion. Needs you to have a activated win8WMC(with your own key), work on the win8.1 wim, the tokens.dat and data.dat are from the win8wmc: dism /mount-image /imagefile:f:\install.wim /index:1 /mountdir:e:\mount Dism /Image:e:\mount /enable-feature /featurename:NetFx3 /All /Source:k:\sources\sxs /LimitAccess dism /image:E:\mount /set-edition:ProfessionalWMC copy e:\tokens.dat e:\mount\Windows\System32\spp\store\2.0 /y copy e:\data.dat e:\mount\Windows\System32\spp\store\2.0 /y dism /image:E:\mount /set-productkey: (your WMC key) dism /unmount-image /mountdir:e:\mount /commit that's it, compile to ISO with the install.wim, install, and get a activated win8.1WMC. You don't have the corrrect files? don't worry: data.dat + tokens.dat : [Zawartość widoczna tylko dla zalogowanych użytkowników] ~~~~~~~~~~~~~~~~~~~ To-day's Sunday, so I did the steps with win8.1 Pro X86 to show : 1. Double click ISO to mount, drive is K: 2. Copy install.wim to C; right click -> properties , untick "read only" ; and also take ownership 3. Made a folder "mount" in E: 4. Have the files tokens.dat and data.dat in E: 5. Carry out the DISM commands, with the correct drive code, and the WMC key, you need to do it in 9600 to work on a 9600 wim. 6. When done, open the win8Pro X86 with UltraISO, replace install.wim with the modded wim, and add file EI.cfg to sources [Channel]Retail [VL] 1 Save to new ISO "win8-1_WMC-X86". 7. I used VMWare to install, when asked for edition, choose "Windows 8.1 Pro"; no need to enter key 8. Done Win8.1Pro+WMC+Net3.5, X86 win8.1Pro+WMC+Net3.5, X64 Note: - I used this WMC key in a previous machine, since WMC key bundles with machine, after installation it is not activated and requires a phone call. - If you don't wish to fight with DISM, you can download the ISO from MEGA, after installation, enter your own key, if it couldn't be activated on-line, make a phone call. Download : X86 ISO: [Zawartość widoczna tylko dla zalogowanych użytkowników] X64 ISO: [Zawartość widoczna tylko dla zalogowanych użytkowników] Note: use WinRAR_5 to unrar, password : pcbeta-com - On theory, if you installed with my ISO, you could make a phone activation, but then if another guy made a phone call, it might deactivate yours ......... not my problem. Hello. Can you refresh links? Because i must have win 8 win media center in iso Cytuj
