x265 HD Benchmark 0.1.4 - test
x265 HD BENCHMARK 0.1.4 RESULTS
Please do NOT compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your
data to [Zawartość widoczna tylko dla zalogowanych użytkowników]
Results for x265.exe build 1.4+5
x265 Benchmark: 64-bit
CRF-20 preset-"fast"
encoded 1128 frames in 75.39s (14.96 fps), 2864.07 kb/s, Avg QP:20.47
encoded 1128 frames in 75.63s (14.91 fps), 2864.07 kb/s, Avg QP:20.47
encoded 1128 frames in 75.42s (14.96 fps), 2864.07 kb/s, Avg QP:20.47
encoded 1128 frames in 75.43s (14.95 fps), 2864.07 kb/s, Avg QP:20.47
System Details
    Name            Intel Core i7 4820K
    Codename        Ivy Bridge-E
    Specification        Intel® Core™ i7-4820K CPU @ 3.70GHz
    Core Stepping        S0/S1
    Technology        22 nm
    Stock frequency        3700 MHz
    Core Speed        3899.8 MHz
Northbridge            Intel Ivy Bridge-E rev. 04
Southbridge            Intel X79 rev. 05
CAS# latency (CL)        8.0
RAS# to CAS# delay (tRCD)    8
RAS# Precharge (tRP)        8
Cycle Time (tRAS)        24
Command Rate (CR)        2T
Memory Frequency        800.0 MHz (1:12)
Memory Type            DDR3
Memory Size            16324 MBytes
Channels            Dual
Windows Version            Microsoft Windows 8.1 (6.3) 64-bit   (Build 9600)
Number of processors        1
Number of threads        8
    Number of threads    8 (max 32)
    L2 cache        4 x 256 KBytes, 8-way set associative, 64-byte line size
    Instructions sets    MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
    Package (platform ID)    Socket 2011 LGA (0x2)
    Temperature 0    35°C (94°F) [0x23] (SYSTIN)
    Temperature 1    47°C (115°F) [0x5D] (CPUTIN)
    Temperature 2    41°C (105°F) [0x52] (AUXTIN)
    Temperature 3    29°C (84°F) [0x1D] (TMPIN3)
bez krecenia  z nowym softem
nowy procek, więc czas na mały teścik skylake i5 6600 non K na ddr3
encoded 1128 frames in 59.20s (19.05 fps), 2903.99 kb/s, Avg QP:20.47
encoded 1128 frames in 58.99s (19.12 fps), 2904.13 kb/s, Avg QP:20.47
encoded 1128 frames in 58.99s (19.12 fps), 2903.97 kb/s, Avg QP:20.48
encoded 1128 frames in 58.91s (19.15 fps), 2904.01 kb/s, Avg QP:20.47
System Details
Name Intel Core i5 6600
Name Intel® HD Graphics 530
Codename Skylake
Specification Intel® Core i5-6600 CPU @ 3.30GHz
Specification PC3-12800
Core Stepping R0
Technology 14 nm
Stock frequency 3300 MHz
Core Speed 798.6 MHz
Northbridge Intel Skylake rev. 07
Southbridge Intel Skylake PCH rev. 31
CAS# latency (CL) 11.0
RAS# to CAS# delay (tRCD) 13
RAS# Precharge (tRP) 13
Cycle Time (tRAS) 35
Command Rate (CR) 1T
Memory Frequency 732.1 MHz (1:11)
Memory Type DDR3
Memory Size 4 GBytes
Channels Dual
Windows Version Microsoft Windows 10 (10.0) Professional 64-bit   (Build 10586)
Number of threads 4
Number of threads 4 (max 16)
L2 cache 4 x 256 KBytes, 4-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
Package (platform ID) Socket 1151 LGA (0x1)
Temperature 1 44°C (111°F) [0x38] (Package)
Power 0 12.66 W (Package)
Temperature 0 41°C (105°F) [0x3B] (Core #0)
Temperature 0 44°C (111°F) [0x2C] (SYSTIN)
Temperature 1 47°C (116°F) [0x5E] (CPUTIN)
Temperature 3 43°C (109°F) [0x2B] (TMPIN3)
Temperature 0 28°C (82°F) [0xBC2] (TZ00)
Temperature 1 30°C (85°F) [0xBD6] (TZ01)
to ja teraz zrobie  test :)
encoded 1128 frames in 90.89s (12.41 fps), 2266.68 kb/s
encoded 1128 frames in 95.46s (11.82 fps), 2266.68 kb/s
encoded 1128 frames in 95.74s (11.78 fps), 2266.68 kb/s
encoded 1128 frames in 94.69s (11.91 fps), 2266.68 kb/s
System Details
Name Intel Core i7 4700MQ
Codename Haswell
Specification Intel® Core i7-4700MQ CPU @ 2.40GHz
Core Stepping C0
Technology 22 nm
Stock frequency 2400 MHz
Core Speed 3197.2 MHz
Northbridge Intel Haswell rev. 06
Southbridge Intel ID8C49 rev. 05
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 27
Memory Frequency 799.3 MHz (1:6)
Memory Type DDR3
Memory Size 16306 MBytes
Channels Dual
Number of threads 8
Number of threads 8 (max 16)
Package (platform ID) Socket 947 rPGA (0x4)
Temperature 0 65°C (148°F) [0xD36] (THRM)
